Sql Oracle remove element lag
I'd like to delete an element from my table in my Oracle database.
I already saw the post
https://knowledge.safe.com/questions/5205/delete-f...
But it doesn't work.
This is my sql query :
FME_SQL_DELIMITER ;
DELETE FROM G_ADT_AGRI.EXPLOITATION WHERE SIRET = 37969607300012
I tried without the FME_SQL_DELIMITER, with the semicolon, with the number between quotes, but it doesn't work anyway.
Please, give me some more ideas.
Thanks
Forum|alt.badge.img+50
Some obvious questions:
  • Are there actually features with SIRET = 37969607300012?
  • Do you have the proper rights on the database?
  • What happens if you do this directly in Oracle?
  • July 21, 2016
If you only have one statement in the SQLExecutor, you should not include the FME_SQL_DELIMITER and make sure to not have a semicolon at the end of your statement.
So your SQL should look like this:
However, make sure to check the data type of the SIRET field. If it's a string you should surround the value with single quotation marks:
DELETE FROM G_ADT_AGRI.EXPLOITATION WHERE SIRET = '37969607300012'
Also, as @redgeographics mentions, copy the statement into SQLDeveloper/Toad or similar and see what happens.
  • July 21, 2016
It exists. I have the rights. In Oracke, it doesn't work either.
But if I I try this query :
FME_SQL_DELIMITER ;
DELETE FROM G_ADT_AGRI.EXPLOITATION WHERE OBJECTID = 650;
It works. Objectid is a number and Siret is a varchar.
If I try to put quotes between the siret number, it doesn't work. The soft run without find a solution.
  • July 21, 2016
As I said, if I do that, the process run without finding a solution or even an end to it script.
  • July 21, 2016
For an unknown reason, the table I was selected was locked. So I have to disconnect and connect to the database to unlocked the table.
I'll post further information when I have it.
