Smallworld points to Microstation V8i cells are different sizes
  • Feb 14, 2017 7:58 PM UTC
  • 110 views
I am translating a group of point objects at different rotations from Smallworld to Microstation V8i. The same object in Smallworld and using the same FME translator. The resulting DGN has different size cells to represent the same object. The point objects that are at 0, 90, 180 or 270 are the correct size when translated but other angles translate larger. I am open to any ideas on why this is happening and what can be done about it.
Thanks
Best answer by robyn_studts
I put in a case ( C123672) with Safe and they are looking into the issue.
  • Apr 12, 2017 2:42 PM UTC
Was anything ever done about this issue? I tried to look up the case but it did not show up.
