Smallworld cable collection import and export issue
  • Jan 23, 2018 2:02 PM UTC
  • 40 views
Dear All,
We are trying to export and import smallworld data by using FME.Actually as per client requirement’s we need to perform two processes by using FME.
Process 1: Smallworld:cables data into Esri Shape files.
Process 2: ESRI shape files to Smallworld database.
We are trying these two processes on Camebride database only. But we are facing issue with cable collection. In cable collection we have “Spec”, “asset” and phase.
  • How to convert these 3 into single ESRI shape files by using FME workbench?
In Process 1 if we read CABLE collection data from Smallworld by using reader we are getting list of feature types.
  • How to import single shape file to Smallworld by using FME. After insert if we check in smallworld it will display all the cable collections.
We are facing issues and we stopped hear.
Request you to please provide suitable solution for doing this task. We need step by step process documentation.
Thanks in advance.
pratap
Forum|alt.badge.img+12
  • Jan 23, 2018 2:51 PM UTC
Add the required SmallWorld feature types as readers and connect to ESRI gdb/ESRI shape writers. Make sure about the mapping of attributes as required.
Once you complete the translation from SW to ESRI then you start concentrating on ESRI to SW. Concentrating both will be cumbersome.
Pratap
