SHP with ZM dimensions to Postgis linestringZ
  • Mar 21, 2013 1:57 PM UTC
  • 5 replies
  • 104 views
Hi all,
I did not found the way to remove the M dimension from a shapefile to include it into a postgis geometry defined as linestringZ.
Do you know the transforer to be used ?
Thanks,
Pierre
  • Mar 21, 2013 2:02 PM UTC
Hi Pierre,
try inserting a MeasureRemover.
David
  • Mar 21, 2013 2:05 PM UTC
Great ! That works fine !
fmelizard
Forum|alt.badge.img+22
  • Mar 21, 2013 6:49 PM UTC
In addition to removing the measure, you can extract the values with the measureextractor and keep the information, if that is desired.
nath
Forum|alt.badge.img+7
  • Sep 12, 2024 6:14 AM UTC
I’v tried the MeasureRemover but it still doesn’t work. Anyone an idea why?
evieatsafe
Forum|alt.badge.img+28
  • Sep 16, 2024 7:29 PM UTC
Hi @nath perhaps you could create a new forum post and include what readers & writers you are using, the version of FME you are using, and even your workspace and logs would be helpful. Unfortunately, this post is from 11 years ago and there has been many updates since. If this is issue is urgent to you perhaps you could submit a support case with us to have someone dedicated to your issue. https://support.safe.com/hc/en-us/p/Support
