Shp to dwg - attributes
  • Feb 10, 2020 3:03 PM UTC
  • 218 views
Hello,
I tested the solution proposed here to convert shp to dwg : https://knowledge.safe.com/articles/18703/how-to-convert-shp-to-dwg-esri-shapefile-to-autoca.html
When I open the dwg in CAO software, I no longer have the attributes associated with the objects.
Which transformers should be used for this ?
Thanks you,
becchr
Forum|alt.badge.img+35
  • Feb 12, 2020 10:28 AM UTC
hi @clo, maybe you want object data in your dwg, is that OK?
In that case using the autocad object data writer is very simple and you don't need any other transformers actually
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/autocad_od/AUTOCAD_OD_writer.htm
