shp renaming based a list while keeping swedish letters in attribute
  • Oct 4, 2016 2:21 PM UTC
  • 89 views
bonbon
I have a folder with 60 shapefiles, they need to be renamed based on a list.
I tired file copy with AttributeValueMapper , but it dosenot keep the special letter in swedish ("ö","ä","å") in the shp attribute.
I donot understand why when I use copy file it will change the shp attribute.
Is there any good solutions
Best answer by takashi
Hi @bonbon, I don't think the File Copy writer changes contents of files. A possible reason I can think of is that the source Shapefile files contain code page files (*.cpg) but they have not been copied into the destination folder. Isn't it such a situation?
  • Oct 4, 2016 3:35 PM UTC
bonbon
  • Oct 5, 2016 6:56 AM UTC
Thank you so much! It is exactly as you said!
