Shapefile Writer: Maximum number of open output files reached, caching additional features until end of translation
Hello,
I am splitting 49 Polygons from one shapefile to 49 separate shapefiles (see inputFile and fmw attached).
In the logfile I get a :
The translation is successful and neither a warning or an error is outputted (see test-fmw-log.txt attached)
All shapefile concerned by the caching are corrupt and I get a:
Worker 2876 > Shapefile Reader: File size and filesize record in header mismatch. File claims size of '108' bytes but is '112' on disk. Reading as many records as possible, but file may be corrupt
I am working with FME(R) 2019.2.0.0 (20191105 - Build 19801 - WIN64)
I think, these kind of translations never had problem...
Thanks for your support.
Florian
debbiatsafe
Forum|alt.badge.img+20
Hi @floriangandor
I'm sorry you're running into this issue. I was able to reproduce the issue using the data you provided in FME 2020.0 and will file a bug report. I will notify you once it has been resolved.
As a workaround, please continue to use the old Esri Shapefile (ESRISHAPE) writer instead of the newer Shapefile (SHAPEFILE) writer.
test-fmw_esrishape.fmw
debbiatsafe
Hi @floriangandor
I'm pleased to announce that this issue has been fixed in FME 2020.0 (build 20218+). Thank you for your patience as we resolve this issue!
  • June 15, 2020
debbiatsafe wrote:
Hi @floriangandor
Hi @debbieatsafe, has this bug/issue been fixed? we're using windows 64bit fme build 20200.
BR andre@mmt
debbiatsafe
BR andre@mmt
Hi @andre
Yes, the issue has been fixed in FME 2020.0, specifically builds 20218+. You can download the latest installers here
