Shape_Length in file geodatabase
  • May 21, 2013 11:35 AM UTC
  • 11 replies
  • 214 views
Input data are in fgdb_1. Ouptut data will be in fgdb_2 which is acctually copy of fgdb_1. One of columns (attributes) is Shape_Length with already known values. In my workbench I am doing some string manipulation and populate some another attribute. Output values for this attribute are being populated without any problem as well as others without changes, except Shape_Length attribute which now has value <Null> for all objects. Right before writing output data I inserted Inspector to check If there is still values for Shape_Length, and yes, values are there. But after writing to fgdb they dissappear. Where is a problem, why values for shape_length are lost? Tips? Database overwrite is set to NO, transaction type is transactions, table drop no, table truncate yes, attribute names are the same of course, i don't know..
  • May 21, 2013 11:57 AM UTC
The shape_length value is usually calculated by the fgdb, so you should't have to specify it yourself. What happens if you remove this attribute before the writer?
David
  • May 21, 2013 12:39 PM UTC
Ok. I removed it and Shape_Length values are <Null> again...I never had before problems with shape fields. just for information, I use FME2013..
  • May 21, 2013 12:43 PM UTC
what happens if you delete the attribute "shape_length" from the Writer altogether?
David
  • May 21, 2013 12:54 PM UTC
Uff. Nothing. Still <Null>.
  • May 21, 2013 1:11 PM UTC
Have you tried with both the ArcObjects and the File API writer?
David
  • May 21, 2013 1:26 PM UTC
With API fgdb I got following error:
"2013-05-21 15:21:18| 61.9| 0.0|STATS |Unexpected Input Remover(TestFactory): Tested 390252 input feature(s) -- 390252 feature(s) passed and 0 feature(s) failed
2013-05-21 15:21:18| 61.9| 0.0|STATS |Unexpected Input Remover Nuker(TeeFactory): Cloned 0 input feature(s) into 0 output feature(s)
2013-05-21 15:21:18| 61.9| 0.0|STATS |Source -> Generic(TeeFactory): Cloned 390252 input feature(s) into 390252 output feature(s)
2013-05-21 15:21:18| 61.9| 0.0|STATS |RiversA (GEODATABASE_FILE_1) Splitter(TeeFactory): Cloned 980 input feature(s) into 0 output feature(s)
2013-05-21 15:21:18| 61.9| 0.0|STATS |RiversL Feature Counter -1 59(TeeFactory): Cloned 389272 input feature(s) into 389272 output feature(s)
2013-05-21 15:21:18| 61.9| 0.0|STATS |ListBuilder_fme_type_remover(TeeFactory): Cloned 389272 input feature(s) into 389272 output feature(s)
2013-05-21 15:21:18| 61.9| 0.0|ERROR |BADNEWS: File C:\\apps\\FME\\metafile\\EvaluateExpression_func.fmf could not be opened (tabrdr.cpp:985)
2013-05-21 15:21:18| 61.9| 0.0|INFORM|Loaded module 'EvaluateExpression_func' from file 'C:\\apps\\FME\\plugins/EvaluateExpression_func.dll'
2013-05-21 15:21:18| 61.9| 0.0|INFORM|FME API version of module 'EvaluateExpression_func' matches current internal version (3.7 20121025)
2013-05-21 15:21:18| 61.9| 0.1|ERROR |BADNEWS: No MULTI_WRITER dataset name was specified (couldn't find a value for `MULTI_WRITER_DATASET') (writrimp.cpp:572)
2013-05-21 15:21:18| 62.0| 0.0|ERROR |BADNEWS: INCLUDE -- failed to evaluate Python script `parms = ["WORKBENCH_DEFLINE_PARMS \\\\"]
if (FME_MacroValues["FMEGEN_DIRECTION"] == "Destination"):
parms.append("\\"GUI CHOICE filegdb_drop_table YES%NO Drop Existing Table\\" \\"NO\\" \\\\")
parms.append("\\"GUI CHOICE filegdb_truncate_table YES%NO Truncate Existing Table\\" \\"NO\\" \\\\")
parms.append("\\"GUI TEXT filegdb_object_id_field Object ID Field\\" \\"OBJECTID\\" \\\\")
parms.append("\\"GUI TEXT filegdb_object_id_alias Object ID Alias\\" \\"OBJECTID\\" \\\\")
parms.append("\\"GUI TEXT filegdb_shape_field Shape Field\\" \\"SHAPE\\" \\\\")
parms.append("\\"GUI TEXT filegdb_shape_alias Shape Alias\\" \\"SHAPE\\" \\\\")
parms.append("\\"GUI TEXT filegdb_config_keyword Configuration Keyword\\" \\"DEFAULTS\\" \\\\")
parms.append("\\"GUI OPTIONAL FLOAT filegdb_xy_tolerance XY Tolerance\\" \\"\\" \\\\")
parms.append("\\"GUI FLOAT filegdb_z_tolerance Z Tolerance\\" \\"0.001\\" \\\\")
else:
parms.append("\\"GUI OPTIONAL TEXT filegdb_where WHERE Clause\\" \\"\\" \\\\")
return parms
' (tabrdr.cpp:1102)
2013-05-21 15:21:18| 62.0| 0.0|INFORM|Trying to find a DYNAMIC plugin for writer named `FILEGDB'
2013-05-21 15:21:18| 62.0| 0.0|INFORM|Loaded module 'FILEGDB' from file 'C:\\apps\\FME\\plugins/FILEGDB.dll'
2013-05-21 15:21:18| 62.0| 0.0|INFORM|FME API version of module 'FILEGDB' matches current internal version (3.7 20121025)
2013-05-21 15:21:18| 62.0| 0.0|INFORM|FME Configuration: No destination coordinate system set
2013-05-21 15:21:18| 62.0| 0.0|INFORM|Writer `FILEGDB_1' of type `FILEGDB' using group definition keyword `FILEGDB_1_DEF'
2013-05-21 15:21:18| 62.0| 0.0|ERROR |Geodatabase Error (-2147220965): This release of the GeoDatabase is either invalid or out of date.
2013-05-21 15:21:18| 62.0| 0.0|ERROR |Could not open File Geodatabase dataset `C:\\path\\fgdb.gdb' for writing.
2013-05-21 15:21:18| 62.0| 0.0|ERROR |BADNEWS: A fatal error has occurred. Check the logfile above for details (dynawch.cpp:107)
2013-05-21 15:21:18| 62.0| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2013-05-21 15:21:18| 62.0| 0.0|ERROR |(fmecloakedwriter.cpp:794) - STFStupidGrouper::initialize(stpdgrpr.cpp:64) - STFWriter::attachGroup - (dynawch.cpp:107)
2013-05-21 15:21:18| 62.0| 0.0|ERROR |BADNEWS: A fatal error has occurred. Check the logfile above for details (multiwch.cpp:770)
2013-05-21 15:21:18| 62.0| 0.0|WARN |Abnormal termination of the Geodatabase reader
2013-05-21 15:21:18| 62.0| 0.0|INFORM|Closing the Geodatabase reader
2013-05-21 15:21:19| 63.4| 1.4|INFORM|=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2013-05-21 15:21:19| 63.4| 0.0|INFORM|Feature output statistics for `FILEGDB' writer using keyword `FILEGDB_1':
2013-05-21 15:21:19| 63.4| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2013-05-21 15:21:19| 63.4| 0.0|STATS | Features Written
2013-05-21 15:21:19| 63.4| 0.0|STATS |==============================================================================
2013-05-21 15:21:19| 63.4| 0.0|STATS |Total Features Written 0
2013-05-21 15:21:19| 63.4| 0.0|INFORM|Closing the Geodatabase reader
2013-05-21 15:21:19| 63.4| 0.0|ERROR |A fatal error has occurred. Check the logfile above for details
2013-05-21 15:21:19| 63.4| 0.0|ERROR |(stftrans.cpp:288) - (simptran.cpp:749) - (stftrans.cpp:318) - (pipeline.cpp:823) - (fctlist.cpp:326) - (fctlist.cpp:381) - (factory.cpp:1112) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttest.cpp:477) - (factory.cpp:1112) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttest.cpp:471) - (factory.cpp:1112) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttest.cpp:471) - (factory.cpp:1112) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fctelem.cpp:726) - (factory.cpp:1112) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttee.cpp:283) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:723) - (factory.cpp:431) - (fcttest.cpp:471) - (factory.cpp:1112) - (factory.cpp:1023) - (pipeline.cpp:982) - (pipeline.cpp:732) - (pipeline.cpp:789) - (simptran.cpp:1077) - (multiwch.cpp:770)
2013-05-21 15:21:19| 63.4| 0.0|INFORM|FME Session Duration: 1 minute 5.0 seconds. (CPU: 58.0s user, 5.3s system)
2013-05-21 15:21:19| 63.4| 0.0|INFORM|END - ProcessID: 5800, peak process memory usage: 1441272 kB, current process memory usage: 1423632 kB
Program Terminating
Translation FAILED.
too bad. I apologize for long post. I just wanted to introduce you with error. Admin can delete it .
  • May 21, 2013 1:57 PM UTC
Strange error, makes me suspect something's wrong with the database.
Try writing to an empty File Geodatabase to see if you get the same error.
David
fmelizard
Forum|alt.badge.img+22
  • May 21, 2013 6:19 PM UTC
I was wondering why are you using the API gdb writer, it has less capabilities than the ArcObjects writer.
As David suggests did you try the ArcObjects writer?
  • May 21, 2013 8:35 PM UTC
Actually, I use ArcObjects fgdb. That was generated error after Davids question whether I use ArcObjects and API. So II used API in this case only to see how it works. :(
  • May 23, 2013 11:41 AM UTC
please could someone try to create one very simple workspace to translate data from one fgdb to another by using ListBuilder and ListExploder and check what happens with Shape_length field. I need this information to check if it has something to do with Lists.
Thank you.
  • May 24, 2013 11:59 AM UTC
Hello, It is me again...It seems to be that by using lists, geometry data are lost. I know that there are some transformers which output features do not have geometry. So the same is with lists. I hope Safe Software support will confirm this.
Today I find another solution how to accomplish my task instead of using lists. It works well.
Thank you for your response.
