Setting FME_RESULT_LIFETIME value on FME Cloud
  • Oct 30, 2015 6:29 PM UTC
  • 6 replies
  • 82 views
mark
Hi
I am using FME Cloud. Please can you let me know how to access \\Server\\fmeEngineConfig*.txt to change the value of FME_RESULT_LIFETIME
Thanks
Mark
Best answer by gerhardatsafe
The cleanup of FME Engine files can now be configured from the Web UI. Please check out our documentation:
https://docs.safe.com/fme/html/FME_Server_Documentation/Content/WebUI/Configuring-System-Cleanup-Settings.htm
fmelizard
Forum|alt.badge.img+22
  • Nov 2, 2015 7:36 PM UTC
Hi Mark
There is currently no easy way to change this parameter on FME Cloud. We have an open development task to add this parameter to the Web UI and there is kind of a workaround, if you contact us through support. Could you please file a support case with us so we can give you full details and connect you with the development task we have open:
https://support.safe.com/knowledgeSubmitCase
Thanks
Ken
mark
  • Nov 11, 2015 1:54 PM UTC
Hi Mark
Thanks
Ken
Hi Ken, I'll submit a case, thanks for your help.
Mark
fmelizard
  • Dec 29, 2015 12:32 AM UTC
@mark for FME Server 2016.0 the cleanup of FME Engine files can now be configured from the Web UI. See this screenshot: https://www.dropbox.com/s/0vcqcadgfq0jm5a/Screensh...
I am trying now to read/write a parameter in FME Server on the cloud but unfortunately the above link is now broken. Would it be possible to upload the file again?
Thanks
Thanks
Hi @alex_chris,
I added a new answer with a link to our documentation for the Cleanup Tasks.
Can you let me know which parameter you want to read/write on FME Cloud? In general, all features should be configurable via the WebUI without needing access to the FME Server configuration files.
Kind regards,
Gerhard Fischl
