Set Excel Reader parameters so they dont have to be set every time a new excel is selected
  • Apr 23, 2018 10:34 AM UTC
  • 5 replies
  • 62 views
I have an excel reader and i convert that to a shape file, which will then be published as a feature service to ArcGIS portal. I will be using this workspace multiple times and will be using new excels each time. My problem is that when i add a new excel the parameters previously specified for the excel before it do not stay the same (i need to specify x and y coordinates).
So when i publish my data to a Portal feature service, my points do not appear on the map but they are in the attribute table.
Is there anything I can do that will just set the parameters for me each time? so i dont have to add a new excel reader and specify x and y coordinates as the data type each time?
I just want to be able to click run with prompt and then select my excel then.
Thanks in advance for your help
nielsgerrits
Forum|alt.badge.img+67
You could save the settings as default. (FeatureReader, configure then Defaults, Save as defaults.)
As an alternative you could save the FeatureReader configured this way in a custom transformer. I would prefer this as I have another default for the FeatureReader. This would be a more elegant solution anyway, using a Published Parameter (Filename Existing) to select the file.
  • Apr 23, 2018 1:50 PM UTC
Thankyou @neilsgerrits, I went with your alternative option!Really appreciate the help!
danilo_fme
Forum|alt.badge.img+58
  • Apr 23, 2018 1:58 PM UTC
Good solution @nielsgerrits
jdh
Forum|alt.badge.img+41
  • Apr 23, 2018 9:47 PM UTC
See this idea. https://knowledge.safe.com/idea/22577/add-option-to-save-as-default-to-writers.html
It was for writers, but could apply equally to readers.
andreaatsafe
Forum|alt.badge.img+17
Hi @mroche162,
You can also set the parameter in the ehe Excel Reader for how to handle additional files. You can find this under Advanced > Additional File Handling and set it to "Apply Current Settings to Additional Files"
Hope this helps too!
