Sequence of stops while using ArcGISOnline Router
  • Mar 7, 2018 5:29 PM UTC
  • 0 replies
  • 24 views
surbhi
How do I figure out how stops are ordered when I use ArcGISOnline Router? I get the optimized route, but I am trying to figure out how to show the sequence of stops in the route.
The information is in the Nodes dataset, but that is generated only if the Return Directions feature is enabled. Also the information is more implied than directly available. It needs some processing. Is there a more direct way of getting to the sequence of stops?
