Sequence increment field in PostGres
  • Sep 7, 2018 5:44 PM UTC
  • 5 replies
  • 179 views
mr_fme
Forum|alt.badge.img+9
In my Postgres database there is one field created directly in database called 'code'.
This field is auto increment.
How I inform to FME that this field exist and none value can be recorded by FME.
I tried record my data without this filed in FME but the ERROR was showed for me.
thank´s
  • Sep 8, 2018 12:13 AM UTC
The PostgreSQL writer should be able to insert records which don't have the 'code' attribute (serial type = auto increment field) into the existing table.
Could you please post the logged error messages? Logged messages are important to know what happened, and also there could be a hint for resolving the issue.
  • Sep 8, 2018 12:31 AM UTC
You can import the schema from the existing table to generate a writer feature type, when adding the writer.
Then, the writer feature type containing a serial type field (named 'code' in this example) looks like this.
mr_fme
  • Sep 8, 2018 2:31 AM UTC
Unfortunately there is no message error. Only the auto increment filed show duplicated.
mr_fme
  • Sep 8, 2018 2:32 AM UTC
I think that your answer help me completly. Thank´s
cww7
Forum|alt.badge.img+3
  • Jul 23, 2019 2:11 PM UTC
Is the name of your sequence defined in the following way: [table_name] _ [field] _seq? If so, FME will automatically recognize the serial type and you will be able to remove the column for Postgresql to fill it automatically.
