Separating comma separated values in a field to create new records
  • Oct 20, 2015 7:47 AM UTC
  • 300 views
jinman1883
I have a table of data that has two fields that have comma separated values in them. Each value is related to each other. So the first comma separted value in Neighbour Code field is related to the first comma separated value in Neighbour Angle field and so on.... The table looks like this
How do I separate these values and create a new record for each value in the fields so the table would look like this:
Thanks
Matt
Best answer by takashi
Hi Matt,
I think this data flow is a basic solution.
Notes:
"Neighbour Angle" should be removed in the upper flow, not to conflict with Supplier's "Neighbour Angle" at the FeatureMerger.
"Conflict Resolution" parameter of the ListExploders should be set to "Use Incoming List".
In addition, the PythonCaller may also be effective in this case.
# Python script example
class FeatureProcessor(object):
    def input(self, feature):
        codes = str(feature.getAttribute('Neighbour Code')).split(',')
        angles = str(feature.getAttribute('Neighbour Angle')).split(',')
        for c, a in zip(codes, angles):
            f = feature.clone()
            f.setAttribute('Neighbour Code', c)
            f.setAttribute('Neighbour Angle', a)
            self.pyoutput(f)
Takashi
  • Oct 20, 2015 9:10 AM UTC
Hi Matt,
Notes:
            f = feature.clone()
            self.pyoutput(f)
Takashi
