Selected only DWG files from a DWG Question.
  • Jul 11, 2025 5:17 PM UTC
  • 5 replies
  • 124 views
probert1968
Forum|alt.badge.img+5
I know I that you cannot delete feature under DWG, but what if you want seleteed a few because one of them is bad.
I am GIS Specialist and I have the DWG files here… The DWG I have is a campgound that somebody worked on it and gave it to use and as I prepare to make a map for that campground and discovered that one of the entity I think “X” is out of  place.
What I was trying to open the 2024.1 Data Inspector and bring that Dataset into the View to see it and
I use the X to turn it off and use the Save As as a new Dataset without the  “X” layer . When I save it and it still  comes with it every time. I tried to use different method.
here is the screen shot I have here.  The one I want to remove this X layer under the DWG Layer is “X” . The Red line I drew is that one that I want to delete it.
I don’t have the latest version to 2025 yet…
Can anyone tell me if there is another way around to fix this ?
  • Jul 11, 2025 7:50 PM UTC
Hi ​@probert1968 ,
You can create a workspace to read the dataset without X layer, if you uncheck X in the "Select Feature Types" window when adding DWG reader to the workspace.
It's also possible to uncheck X layer in the "Feature Types to Read" parameter of the reader on the Navigator window after adding the reader with X layer, not to read the layer.
No need to create a new DWG dataset without X layer anyway.
probert1968
  • Jul 11, 2025 8:21 PM UTC
For the workspace,  just open in FME  Workbench ?
  • Jul 11, 2025 8:25 PM UTC
Yes, open FME Workbench, then Add Reader to the workspace.
probert1968
  • Jul 11, 2025 8:30 PM UTC
So then I use the individual to open the next dialog box and uncheck the X layer. Now It is adding to the workspace. Now how do I save them to a new DWG ?
probert1968
  • Jul 11, 2025 9:07 PM UTC
Thank you ! I fixed it and it was so much easier even though I am new to it.
