SDE Connection Files and Versions
  • Jun 18, 2020 2:28 PM UTC
  • 111 views
I'm trying to figure out a way to create a couple of paramaters in my workflow so that the user can select from a picklist of SDE Connection Files and available Versions to use in the various FeatureReader transformers in the workflow. Is there a way to do this without hard-coding all the values in ahead of time??
Thanks,
stalknecht
Forum|alt.badge.img+22
  • Jun 18, 2020 7:24 PM UTC
What I would do is put the connectionfiles in a folder. Use the "Directory and filepath names"-reader to output the list to a csv. Then you can import all the items in the parameter.
hope this helps
  • Jun 18, 2020 7:32 PM UTC
Thanks @stalknecht. But what I'm looking for is something a bit more dynamic. The workflows I am working on are meant to be shared amongst a group of users, and there is a high likelyhood that people will name their connections differently than what is in a static list.
With the FeatureReader transformer, it presents a list of both SDE Connections and Versions to the user through the Parameters button. Is there not a way to tap into those lists and attach them to a paramater somehow??
stalknecht
  • Jun 18, 2020 8:39 PM UTC
I think you need a workspacerunner because parameters are evaluated before the translation or maybe a scripted parameter.
