Salesforce Writer appears to be stopping after 200 records
  • Mar 31, 2017 3:20 PM UTC
  • 0 replies
  • 35 views
I have a transformation from Oracle Non Spatial to Salesforce that works fine until there are more than 200 records. At that point it errors. I can't tell from the error message what the issue is exactly. Is it some setting in Salesforce? Do I not have the parameters set correctly on my Reader/Writer? Any help would be appreciated. I do know that the records after 200 do not have data issues as I can write them only not when they are greater than feature 200.
Salesforce Writer: Record 201 was not processed successfully: 'CANNOT_INSERT_UPDATE_ACTIVATE_ENTITY:InternalServiceOrderTrigger: execution of AfterUpdate caused by: System.NullPointerException: Attempt to de-reference a null object Class.InternalServiceOrderTriggerHandler.emailRelatedServiceOrderSDC: line 668, column 1 Class.InternalServiceOrderTriggerHandler.triggerHandler: line 93, column 1 Trigger.InternalServiceOrderTrigger: line 4, column 1:--'
