Revit support in FME Desktop
  • Feb 16, 2018 3:29 PM UTC
  • 95 views
I've a large installed base of Revit with versions from 2016 to 2018 and one of the worst problems we are dealing with is the incompatibility between these versions. I would like to know if FME Destkop can act as an intermediary in order to read from one version and write to a different one. Maybe the plugin for Revit and the rvz format could be the solution, but I'm not sure about this (I didn't have explored this). Thanks a lot!
Best answer by daveatsafe
Hi @jcglez2,
FME can currently only read Revit data (through the RVZ exporter). We are working on adding both direct Revit reading and writing, but this is a long term project.
daveatsafe
Forum|alt.badge.img+24
  • Feb 16, 2018 5:49 PM UTC
Hi @jcglez2,
nic_ran
Forum|alt.badge.img+20
  • Sep 25, 2018 2:47 AM UTC
Hi @jcglez2,
Hi @DaveAtSafe,
the docs for the Revit reader (exporter) only indicate support for Revit 64-bit versions 2013-2016, however, this link (https://knowledge.safe.com/questions/38293/fme-exporter-for-revit-2017.html) indicates that 2017 is supported. Can Safe please advise which versions of Revit are currently supported with the Exporter in FME 2018.1?
Can the docs please be updated to reflect currently supported versions?
thanks,
Nic
daveatsafe
  • Sep 25, 2018 3:56 PM UTC
Hi @DaveAtSafe,
thanks,
Nic
Hi @nic_ran,
The FME 2018.1 Exporter should run in Revit 2018. I will try to get the docs updated, but we should have direct Revit reading for FME 2019. The current Revit reader in FME can also read IFC files, so Revit's built-in IFC exporter is a good alternative for those using Revit 2019.
nic_ran
  • Sep 26, 2018 1:04 PM UTC
Hi @nic_ran,
Thanks @DaveAtSafe
