revit model export rvz lose something
  • Nov 20, 2017 3:16 AM UTC
  • 5 replies
  • 106 views
Hi, there is a revit model that is normal when exporting ifc, but some models are lost when exported as rvz files. Lost this part of the model is mainly the use of structural framework order to create the components, especially the arc-shaped parts easily lost.
IFC4
RVZ
Revit File:
revit file_google drive
revit file_one drive
Thanks.
  • Nov 27, 2017 4:00 AM UTC
hello
I also meet this problem when I convert revit model to rvz format. I haven't solved this problem until now.
Have you solved the problem now? If you solve the problem, can you tell me how you solved it?
thanks a lot !
  • Nov 27, 2017 4:57 AM UTC
Unfortunately, I haven't solved the problem yet. I hope the authorities can solve it.
I downloaded and tested your model. Unless there are some very specific uses and requirements that are needed from IFC4, I would suggest exporting to RVZ or IFC using IFC 2x3 instead. When I exported your model and opened it in FME Inspector and Workbench, everything shows up as it does in Revit. Additionally, there have been issues with Revit exports to IFC4 in general, where geometries go missing.
Hope that helps.
  • Nov 28, 2017 2:56 AM UTC
I didn't find a solution either, and I am trying to replace RVZ with the IFC. If I find a solution to this problem, I will inform you immediately.
Good luck!
