Reproject Point Cloud
  • May 29, 2019 9:02 AM UTC
  • 303 views
Hello!
I have to transform a PointCloud Dataset (LAS) from EPSG 31256 to EPSG 4326.
Therefore I used the transformer CSMapReprojector. My output PointCloud always looks like this:
This was the Input dataset:
Thanks for your suggestions.
  • May 29, 2019 9:55 AM UTC
The units of x, y coordinates in EPSG 31256 are meters, whereas the units in EPSG 4326 are degrees. I think the difference in the units of x, y coordinates causes such a strange (but correct I think) result.
Thank you for the hint @takashi. I think the Problem is laying in the vertical Transformation (heigts) from EPSG 31256 to EPSG 4326. I now started using the CSMapReprojector instead of the Reprojector to also define the vertical handling. (which is by Default "Ignore height and leave them unchanged") @daveatsafe Do you maybe know which vertical handling I can use for the reprojection of a PointCloud from MGI GK East to WGS84?
I tried a las file (I set projection ex. 31256 at reader and 4326 at writer). it is working but there is a problem with the inspector. I opened the result with globalMapper and it is correct. Tr to open the result with another software.
  • Jun 4, 2019 2:05 AM UTC
The 3D renderer of FME Data Inspector doesn't support reprojecting on the fly, so I think it's natural that 3D objects looks strangely on the View if the units of z-coordinate are different from the units of x, y-coordinates.
