Replacing old Shapefile Writer with a 2013 Shapefile Writer
I am trying to update some old workbenches we have.  Looking at our shapefile writers, we would like to use the 'spatial index' functionality that is available in FME 2013.  I am looking for an efficient way of adding a new shapefile writer and then coping over the attributes and other properties from the old shapefile writer.
Is there a non-manual way of doing this?
Thank you for your time,
Julia
Best answer by mark
Probably the easiest way is to use Writers > Add Writer from the menubar, then open a feature type and change the Writer from the old one to the new one. Use "Apply To...." if there are multiple feature types. Then delete the original Writer, which should now have no feature types attached to it.
Hope this helps
Mark
Mark Ireland
Safe Software Inc
<strong>This post is closed to further activity.</strong><br /> It may be a question with a best answer, an implemented idea, or just a post needing no comment.<br /> If you have a follow-up or related question, please <a href="https://community.safe.com/topic/new">post a new question or idea</a>.<br /> If there is a genuine update to be made, please contact us and request that the post is reopened.
  • June 24, 2014
Hope this helps
Mark
Mark Ireland
Safe Software Inc
  • June 26, 2014
Mark - This was perfect!  Thank you.
