Replace default Imperial Autocad templates with Metric versions
  • Apr 27, 2017 3:12 AM UTC
  • 91 views
kimo
Forum|alt.badge.img+10
Since every country in the world except The USA, The Gambia and Myanmar is now using metric units could we have a set of default templates in FME in metric units? Or at least an option to switch back to Imperial?
Does anyone in a metric country have a set of default.dwg, (and 2007, 2010, 2013 versions) for FME that they could share?
daveatsafe
Forum|alt.badge.img+24
  • Apr 27, 2017 4:07 PM UTC
A very good question! I have created an enhancement request to have this done.
kimo
  • Apr 27, 2017 11:04 PM UTC
I notice that Autocad uses a template format *.dwt that is common on the web. Would that be a better format to support since there are many templates for different applications readily available. eg Civil_Metric.dwt might be better for utilities than the plain defaultISO.dwt
daveatsafe
  • May 2, 2017 5:45 PM UTC
FME can use .dwt files as well for the template files - just choose *.dwt for the file filter.
You can find a useful set of templates at https://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-2017-templates.html.
kimo
  • May 3, 2017 10:12 PM UTC
What about the defaults in the Autocad folder? Can these be .dwt files. Could I rename Civil_Metric.dwt default.dwt? I cannot find any historic templates. What is an easy way to check the units in an Autocad drawing? I see it is a major issue even for Autocad users. I had an idea to export the template to a DXF file which can then be read as a text file. It appears that units names are not stored in the drawing, the coordinates are just numbers. I thought I would find a page name for A1 and did in an AcDbBictionary. Is that all?
