Removing Surrounding Parentheses in a Field
  • February 13, 2025
  • 46 views
jugoslaviaa
I have a field that contains values with parentheses, like (0601310951181134359628), and I would like to remove them. The parentheses always appear once at the beginning and once at the end of the field.
I am currently able to achieve this using two StringReplacer transformers, each removing one parenthesis. However, I would like to do it in one step. I tried the recommended regex expressions from previous posts, but none of them worked.
Any suggestions?
Best answer by david_r
If you want to only remove parenthesis at the beginning and end of the string, and not inside the string:
  • February 13, 2025
You can try this:
It will remove any paranthesis (open or close) wherever inside “my_field”.
Here’s the regex for copy-paste purposes:
geomancer
Forum|alt.badge.img+50
  • February 13, 2025
You have to escape the parantheses. This works:
Search for ( or ). Replace with nothing.
Note that this will replace every ( and )
  • February 13, 2025
