remove overlaps in pointcloud ?
  • May 25, 2018 9:17 AM UTC
  • 70 views
Is there a tool or workflow to remove or classify overlaps in a LAS file?
jneujens
  • May 25, 2018 9:52 AM UTC
Overlaps of what exactly? 2 seperate point clouds?
If you know where the overlap occurrs, you can filter out these zones in your pointcloud.
But probably you can use the components of the pointcloud to solve your problem?
A tool which classifies LAS points from overlapping scans
