Remove fme format attributes from Generic Reader
  • Sep 28, 2012 4:19 PM UTC
  • 118 views
fmelizard
Forum|alt.badge.img+22
Generic Reader is outputting extra fme format attributes. Eg:
 mapinfo_symbol_color
 db_type
 jpeg_type
 csv_number_of_fields   I want to drop all these attributes leaving only the 'native' attributes but it is hard to do this with a text filter since the pattern varies depending on the input format.  Any ideas?   Unfortunately I can't just ignore them in the writer because I am writing the list of attributes to a string.
Best answer by kathyross
You could try using the AttributeExpressionRemover. As you say though, that would involve alot of work and complexity.
Have you tried the SchemaReader reader to populate a list of attributes?
Alternatively, maybe even a custom python solution may be the way to go if you're up for it. I know that there is at least one fmepedia article that i've used to sort out a dynamic attribution solution in the past with Python.
Good luck.
kathyross
Participant
Forum|alt.badge.img+9
  • Participant
  • Oct 2, 2012 2:22 AM UTC
Good luck.
