Regarding oracle spatial server changed or Hostname changed
  • Dec 9, 2012 10:12 AM UTC
  • 45 views
I have developed many workbences having parameters username=ADPUGSD Servicename : Stage . But I want to move my data into another server having another servicename : 'stage_new' .
Then I will modify scripts with changes in parameters on writer side or I will add another writer and then mapped to source. Pls clarify & do needful asap
Best answer by sigtill
If you look on the left side of the workspace you see the writer and its parameters. If you right click on the SERVICENAME-parameter you can "Create Published Parameter". This way you can input the SERVICENAME when the workspace is started.
http://fmepedia.safe.com/articles/FAQ/Published-Parameters
sigtill
Forum|alt.badge.img+25
  • Dec 9, 2012 8:07 PM UTC
