Reading Xml Files from a specific External directory by Server published workbench
  • Jul 23, 2013 5:55 PM UTC
  • 67 views
  My workbench is able to read xml files in FME desktop. While publishing, i upload needed files along with it and it works fine. But each time to change fil list, i have to download workbench and modify reader source file list.
First please tell me how to read xml files using publish parameters.
Second, How can i make this dynamic?like placing xml files in a directory and pointing my workbench to read all xml files inside that.
Thanks.
Subrat
fmelizard
Forum|alt.badge.img+22
  • Jul 23, 2013 8:05 PM UTC
To open similar datasets use the advanced browser poiting to your XML input directory.
Also use the UNC path when uploading to FME server.
Hope this helps,
Itay
fmelizard
  • Jul 24, 2013 6:08 PM UTC
Hi Subrat,
If you are sure about the path, then the only issue I can think of, are premissions on that shared folder. Does FME server have the correct set of permissions?
Itay
