reading netcdf 4
  • December 14, 2016
  • 9 replies
  • 54 views
trembathp
I am unable to read a netcdf4 file into fme (2015, 16 or 17).
I get the following error:
NETCDF reader: `C:/Users/phtr/Desktop/TCI_ref_to_month_europe_2000_v1.nc' not recognized as a supported file format.
NETCDF reader: Failed to open the dataset 'C:/Users/phtr/Desktop/TCI_ref_to_month_europe_2000_v1.nc'. Please ensure source data is valid and correct reader is selected
A fatal error has occurred. Check the logfile above for details
Failed to obtain any schemas from reader 'NETCDF' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
If I convert the input to netcdf 3, FME can read it OK.
Is anyone else having this issue?  Is it a know limitation of FME?
Many thanks
Best answer by jdh
Per the documentation FME supports up to version 3.6.2 of netCDF.
I suggest contacting support and requesting it and voting on the idea https://knowledge.safe.com/idea/28450/update-to-netcdf-format.html
jdh
Forum|alt.badge.img+28
  • December 14, 2016
david_r
  • December 15, 2016
@jdh is right, NetCDF 4 isnt't supported by FME and it's a known limitation.
Another, more peculiar limitation, is that FME cannot read NetCDF files >2GB on the Windows edition, although the Mac and Linux editions can, apparently.
It would be great if the NetCDF libraries could be upgraded soon.
scyphers
Participant
  • Participant
  • May 16, 2017
@jdhI I am strongly considering making a workaround for NetCDf4 data using either nccopy.exe as a third party tool or this python script to save netCDf4 as netCDF_classic (v3) to then read it through.
I suggested it as my #fmeuc hackathon topic/group at the very least we should be able to wrap up a workaround process to make the data readable. As there is some netCDF4 data i would very much like to tackle with FME.
the python recipe i have found is here : https://gist.github.com/guziy/8543562#file-converter-py it will require numpy, netCDF4 dependencies to make it work. And you can expect up to 8x bloat of your netcdf4 data moving to netcdf_classic so i hope you can acheive <2gb limits in your input data. If you have opportunity to come to the User Conference let solve it together, and post something in the FMEHUB!
david_r
  • May 17, 2017
Great idea, I'd be glad to join, just let me know.
A few years ago I already did something similar using the Python GDAL bindings to access the individual cell values in a classic NetCDF without having to coerce it into individual features first. The performance gains were pretty spectacular compared to using the RasterCellCoercer.
tono
Forum|alt.badge.img+11
  • August 6, 2018
Any news regarding support for Netcdf4 format?
david_r
  • August 6, 2018
NetCDF4 is supported starting with FME 2018.
tono
  • August 6, 2018
I have tried Sentinel 5p data with FME(R) 2018.1.0.0 (20180606 - Build 18493 - WIN64) and i get this error:
"NETCDF reader: Opening file 'C:/Temp/data/S5P_NRTI_L2__NO2.nc'
NETCDF reader: C:/Temp/data/S5P_NRTI_L2__NO2.nc is a netCDF file, but without any dimensions >= 2.
NETCDF reader: `C:/Temp/data/S5P_NRTI_L2__NO2.nc' exists but could not be opened. File contents may be invalid, or the file format may not be supported
NETCDF reader: Failed to open the dataset 'C:/Temp/data/S5P_NRTI_L2__NO2.nc'. Please ensure source data is valid and correct reader is selected
FME Session Duration: 0.3 seconds. (CPU: 0.1s user, 0.0s system)
END - ProcessID: 12744, peak process memory usage: 48604 kB, current process memory usage: 43448 kB
Program Terminating
Translation FAILED."
Any clue about fail?
Thanks in advance
david_r
  • August 6, 2018
Program Terminating
Thanks in advance
Unfortunately I have no experience with Sentinel data, my suggestion would be to send the NetCDF together with a demo workspace and log file to Safe support.
Since the NetCDF 4 support is so recent, there's always the possibility that there's an edge case that needs to be taken into account.
tono
  • August 6, 2018
Done. Case sendt. Example data can be downloaded here: https://s5phub.copernicus.eu/dhus/#/home
