Reading MicroStation V7 custom line styles
  • Apr 18, 2016 6:23 PM UTC
  • 141 views
Trying to read Microstation V7 dgn files in FME desktop. How do you add .rsc file so that custom line styles and symbols can also be included?
pratap
Forum|alt.badge.img+12
  • Apr 19, 2016 5:37 AM UTC
Hi @arunm,
I did not understand the purpose of adding it as you have done in Microstation. FME will read the custom lines styles and symbols as they exists and show the name in prescribed attributes.Pass the features to inspector and check it once.
Pratap
  • Apr 19, 2016 7:36 PM UTC
@pratap
I am reading V7 design files without problems. When I review the output in Data Inspector, the custom symbols appear as points. The custom line styles do not display.
These are defined in a separate .rsc file that I have. How do I incorporate these definitions in FME?
Thanks!
Arun
pratap
  • Apr 20, 2016 3:40 AM UTC
As far I know, adding rsc file exists in writer (only for font) but not in reader of dgn file. In inspector, symbols will be shown as they are (without rsc file) and for custom line styles, you can see in respective linestyle attribute.
Pratap
pratap
  • Apr 21, 2016 4:02 AM UTC
For symbols, you have to opt "Yes" in Expand Named Cells option in dgn parameters then symbol will be exploded and you can see the symbol as it is in viewer. But do note that symbol will be exploded.
I don't think you can see exactly as defined in rsc file but you can get the linestyle name in attribute.
