Reading KML with Tracks
  • Jun 6, 2017 2:39 PM UTC
  • 12 replies
  • 192 views
mapper
Forum|alt.badge.img+7
I am trying to read some kml files that were exported from Avenza PDF maps. The KMLs contain Lines, Points, and Tracks. I am able to read the lines and points just fine but the tracks are not output from the reader. Is there some way of exposing the Tracks?
jdh
Forum|alt.badge.img+41
  • Jun 6, 2017 2:46 PM UTC
Can you post a sample of the output KML?
mapper
  • Jun 6, 2017 2:53 PM UTC
mapper
  • Jun 6, 2017 2:56 PM UTC
I have uploaded one of the kml's containing several tracks
  • Jun 6, 2017 4:06 PM UTC
Based on your sample kml file, the tracks seem to be output as a Placemark feature, but they do not have any geometry. You can isolate them using a GeometryFilter and by connecting an Inspector to the Null geometry output.
In the Inspector, click on one of the <no schema> features and inspect the format attributes in the Feature Information window:
As you can see, the tracks have several attribute lists (some of them nested) that you'll have to expose manually in your workspace (AttributeExposer) and then also process manually.
Some of the attribute names you should (or could) expose include:
kml_gx_track_extendeddata_schemadata_gx_simplearraydata{}_name
kml_gx_track_extendeddata_schemadata_gx_simplearraydata{}_gx_value{}
kml_gx_track_gx_angles{}
kml_gx_track_gx_coord{}
kml_gx_track_when{}
kml_name
kml_parent
If you need to construct the track geometry, you will probably have to build the track line manually using the kml_gx_track_gx_coord{} list, e.g. using a combination of the ListExploder, AttributeSplitter and VertexCreator.
mapper
  • Jun 6, 2017 9:34 PM UTC
kml_gx_track_when{}
kml_name
kml_parent
I'm still having trouble exposing any of the lists including the kml_gx_track_gx_coord{} list.  Its not in the format attributes dialog so I have tried to expose it with the AttributeExposer but when it gets to the ListExploder all features come out of the rejected port. I am assuming it is rejected because it is not finding the list.
jdh
  • Jun 6, 2017 9:44 PM UTC
That's because the first element in the coord list is not 0.
rename kml_gx_track_gx_coord to kml_gx_track_gx_coord{0} prior to exploding
jdh
  • Jun 6, 2017 9:48 PM UTC
Try the following workspace kml-extendedschema.fmw.
mapper
  • Jun 6, 2017 10:16 PM UTC
Thanks renaming kml_gx_track_gx_coord to kml_gx_track_gx_coord{0} prior to exploding was the ticket but the complete workbench was much appreciated!
arnold_bijlsma
Forum|alt.badge.img+16
Without having seen this reply, I got to exactly the same solution! The only difference being that I was just using the more generic XML reader:
mark2atsafe
Forum|alt.badge.img+59
Looks like tracks aren't yet (officially) supported. It's already filed as PR#37822 - I'm going to add a link to this thread and increase the priority.
Hi Mark,
Could you confirm by when the feature PR37822 is officially supported in FME?
Thanks,
Ruchi
mark2atsafe
Hi Mark,
Thanks,
Ruchi
Not yet I'm afraid. I've added your details to the request so you are informed when it is done. I honestly don't know when that will be. If you have a solid business case for implementing this, then please let us know via either support (safe.com/support) or your sales contact/reseller.
