Reading google sheets that contain pull down list data
  • Nov 22, 2018 12:39 AM UTC
  • 66 views
My import was working when I was using Excel with data validation but I put all the data in google sheets, where it needs to be, and now the sheets won't read. Both sheets have attributes whose values come from a pull down list. There is then a third attribute with a rate that I need. The rate is then joined to another table based on the first two attributes matching. I am using a featurejoiner to join the google sheet to the other table. Is there a problem reading this type of file? What is the solution?
danilo_fme
Forum|alt.badge.img+58
  • Nov 22, 2018 5:02 PM UTC
Hi @tsurveyor
I dont know if there is a problem to read a table sheet from Google.
Could you share us the print ( your Workspace ) and Log to investigate better?
Thanks,
Danilo
  • Jan 14, 2019 10:39 PM UTC
purely operator error
