Reading generic XML with variable content ?
  • Feb 15, 2017 2:53 PM UTC
  • 5 replies
  • 93 views
lifalin2016
Forum|alt.badge.img+42
How can I best accomplish reading a generic (any) XML file without specifying any initial root tags etc. ?
I.e. return the whole XML document as a single fragment.
Do I need to create some special XRS or xfMap templates, or can it be accomplished with the simpler Feature Paths ?
Cheers
Best answer by takashi
Hi @lifalin2016, the XML reader can also be used.
When adding the reader, check the Single Merged Feature Type for the Workflow Options in the Add Reader dialog, and set writer parameters as below.
  • Configuration Type: Feature Paths
  • Feature Paths Configuration/Elements to Match: //*
  • Flatten Options: Uncheck the Enable Flattening checkbox
Here, the //* (two slashes and an asterisk) indicates the document root element with any name.
If you read an XML document with this setting, the reader feature type will output a single feature having "xml_fragment" attribute, which stores the entire XML document.
[Addition] /* (a single slash and an asterisk) seems to work too.
Forum|alt.badge.img+63
If you just want a single fragment you might as well use a TextLine reader and set it to read the whole file at once. You'll then get a single feature with one attribute containing your entire XML file. You wouldn't be able to do much with it though, so are you sure that's what you want?
itay
Forum|alt.badge.img+19
  • Feb 15, 2017 5:42 PM UTC
an idea is to first analyze the xml for its tags and pass that to a second workspace or feature reader to read the xml.
  • Feb 16, 2017 10:09 AM UTC
lifalin2016
  • Feb 21, 2017 12:28 PM UTC
Thanks Takashi, it worked.
I needed to read multiple XML files in a ZIP package to ensure before attempting a translation that they don't contain any errors. And each XML file has its very own schema setup, hence the need to read "generically".
Unfortunately the XML files in question are generated by an external tool outside our jurisdiction that clearly doesn't validate its own output, so we have to make sure we don't waste hours trying to import them needlessly.
This approach may come in handy in other cases too :-)
Cheers
itay
  • Feb 21, 2017 12:50 PM UTC
note to myself: read carefully!!!
