Reading from MS Access is SUPER SLOW
  • Aug 23, 2018 5:32 PM UTC
  • 12 replies
  • 216 views
Hello: I'm experiencing very slow read speeds from one (1) Access database table that only has approx. 114K records in it. This is also a local copy of the database (.mdb) file (did so to rule out network latency). Is there some trick to increase the read speed for Access?
  • Aug 23, 2018 5:36 PM UTC
Is there a WHERE-clause defined in the reader? If yes, are the referenced fields indexed?
  • Aug 23, 2018 5:43 PM UTC
No WHERE clause at all. It's just a simple read on all records in the table.
  • Aug 24, 2018 7:35 AM UTC
Have you tried compacting the mdb first?
itsmatt
Forum|alt.badge.img+48
  • Aug 24, 2018 10:31 AM UTC
How slow are we talking here - any resorsouce warnings in your log file?
fmelizard
Forum|alt.badge.img+22
  • Aug 27, 2018 11:16 PM UTC
Curious what platform you're on, and if you tried the JDBC MS Access reader as well. That one has greater performance in our tests. Wondering if there may be something special about your dataset too -- if you're willing to share it, please do send in to support@safe.com or post it here.
  • Aug 30, 2018 4:39 PM UTC
The data is rather sensitive but I could try the JDBC MS Access reader to see if that improves things.
Thanks! I'm not the owner of the data but I can contact the developer to give this a try.
  • Jul 16, 2019 1:55 PM UTC
I'm experiencing the same problem. Reading an .mdb database of 200 MB with FME workbench is taking me close to 2 hours to read with the MSACCESS_JDBC reader. I've added the following environment variables in >tools> Edit Header
FME_JVM_MIN_HPEAP_SIZE: 1024M
FME_JVM_MAX_HEAP_SIZE: 16384M
And the improvement is quite minimum (~10% improvement).
Any suggestions?
In case it helps, mdb_process_test.txtI attach the log file where I am reading only a few MB of the database, and it still takes almost 2 minutes:
Thanks!!
  • Jul 16, 2019 1:58 PM UTC
Any suggestions?
Thanks!!
Is the input file on a local drive or on a network share? Are you running a fairly recent version of FME?
I'm experiencing the same problem with a 173MB Access database. I've copied the Access database locally and compacted it for only a small performance gain.
Used ADO drive instead of JDBC driver an much much faster!
  • Feb 14, 2020 12:23 PM UTC
My apologies for not responding in time. That is good to know. One of the issues I had at the time (I later discovered) was network latency issues. At the time to remedy this, I simply copied the access database locally to perform my processing. So even with the JDBC driver, I experienced more efficient processing. I may try to run this process from the network location with the ADO driver to see if that makes a difference. Thanks!
