Read From SQL Reporting Service and convert to a Shapefile?
  • Nov 17, 2019 2:19 PM UTC
  • 69 views
Hello, I was wondering if there is any way I can save a report from SQL Reporting Service into a shapefile? This lit building report has lat/lon and If I can grab from one of the formats it exports and then convert to a point shapefile, that would be my end goal. I have tried saving the excel using HTTPCaller to a folder then writing that to shapefile, but it has not been able to get the file. Is there another way that I should be going about this if it is possible? I would most likely not be able to get access to the backend database due to IT Assurance.
Forum|alt.badge.img+63
Excel looks like it would be the most promising option. If the Latitude and Longitude columns are in the file you can use a VertexCreator to create points and write them to a Shapefile.
However, if you can't get access to the file it's all a bit moot (assuming you don't want to manually export and save the excel every time)
  • Nov 18, 2019 12:22 PM UTC
OK, the excel reader worked, what I was missing was having it use my windows sign on credentials to pull the file! Thank you!
