Read ESRI Geometric Network rules and definitions
  • Mar 14, 2026 4:13 AM UTC
  • 77 views
cavarly
Hi, I was wondering if anyone has succeeded in reading an ESRI SDE geometric network configuration - rules etc. ?
I would like to export to a readable format for reporting.
From research , all Arc Catalog 10.6. tools are no longer available for these kind of things. No arcpy either.
So possibly an SQL approach, but I don’t know even in which tables such things might be found.
trentatsafe
Forum|alt.badge.img+7
Hi ​@cavarly
It looks like you might be able to find the information in the tables listed here: https://desktop.arcgis.com/en/arcmap/10.6/manage-data/gdbs-in-sql-server/dataset-internal-tables.htm#ESRI_SECTION1_9FF9489173C741DD95472F21B5AD8374
Specifically, the section under Geometric Networks. This QnA on Esri’s forums may also help.
