Read dynamic (from sde) and write to dynamic (mapinfo)
francis_m
Hi!!!
I read a SDE (SQL) database and write dynamic MapInfo table (dynamic is because I want my output to be like my SDE Database).  Eveything is fine except with the "date" type attribute.  MapInfo write the date as a "DateTime" attribute.
But I'd like to have a simple "Date" attirbute.  Any idea how to force "Date" and not "DateTime" on a dynamic transformation using Dynamic Properities of the  SDE Geodatabase ?
thank you!
Best answer by takashi
The strategy is:
- Read schema features from the source dataset.
- Modify data type name in the schema feature.
- Merge the schema feature (list attribute) to the data features.
- Configure the Dynamic Properties with "Destination Schema is Derived from List Attributes" method. (https://knowledge.safe.com/articles/Samples_and_Demos/Dynamic-Workflow-Tutorial-Destination-Schema-is-Derived-from-List-Attributes)
(1) Add a Schema (Any Format) reader to the workspace, link its Dataset to the existing SDE reader's Dataset.
(2) The schema features have "attribute{}.fme_data_type" which contains FME generic data type names as its element. Here, replace every "fme_datetime" in the list with "fme_date". One possible way is to use a PythonCaller with this script, for example.
def processFeature(feature):
    i = 0
    while True:
        attrName = 'attribute{%d}.fme_data_type' % i
        t = feature.getAttribute(attrName)
        if t == None:
            break
        if t == 'fme_datetime':
            feature.setAttribute(attrName, 'fme_date')
        i += 1
If you are not familiar with Python, you can also use a NullAttributeMapper instead.
Map: All Attributes
If Attribute Value Is: <No Items Selected>
Or If Attribute Value Is: fme_datetime
Map To: New Value
New Value: fme_date
(3) Add a FeatureMerger; send the data features (from the existing SDE reader) to the Requestor port; send the modified schema features to the Supplier port.
Join On
Requestor: fme_feature_type (expose in the reader)
Supplier: fme_feature_type_name (note that it's not "fme_feature_type")
(4) Send the Merged features to the dynamic writer feature type, and configure the Dynamic Properties.
In FME 2015.1+:
Select "Schema from first feature" as the "Schema Sources".
In FME 2015.0 and earlier:
Add a NULL reader to the workspace as a Workspace Resource (Menu: Readers > Add Reader as Resource), and then select it as the "Schema Sources".
Hope this helps.
Takashi
takashi
  • October 27, 2015
The strategy is:
    i = 0
    while True:
        if t == None:
            break
        i += 1
Map: All Attributes
Map To: New Value
New Value: fme_date
Join On
In FME 2015.1+:
Hope this helps.
Takashi
takashi
  • October 27, 2015
P.S. You may have to specify the "Input Format" parameter of the Schema reader explicitly.
francis_m
  • October 27, 2015
This is perfect Takashi !
It works fine, I just used a FeatureReader (with Schema (Any Format)) instead of the reader directly.
Thank you Takashi!!!
