RasterMosaicker gaps
  • Oct 9, 2024 7:55 PM UTC
  • 164 views
mr_fme
Forum|alt.badge.img+9
I have a dataset with 8 images. Look below at the images together:
After using the Raster Mosaicker, the output is 1 image like this:
What could I have done wrong in the transformer, or what else is necessary?
Thanks.
Best answer by crystalatsafe
Hi @mr_fme
You could try changing the Data Values parameters, particularly the Overlapping Values parameter. By default the last value in will win, so if a raster with empty space comes in after a raster that has meaningful values in that area, the empty space will overwrite the meaningful values since they arrived later. Changing the data value parameters may help with this, here are a few things you could try:
  • If your data has an alpha band, setting Overlapping Values to Composite Using Alpha Band will likely have the best result.
  • If your data has nodata values, ensure that Nodata Overwrites Data is No. You may also need to set the no data value before the RasterMosaicker.
  • If your data has neither alpha nor nodata, you could try setting Overlapping Values to Minimum, since white would be (255, 255, 255), so any real value would be less than that.
Please let me know how this goes and if you have any questions.
Crystal
crystalatsafe
Forum|alt.badge.img+32
  • Oct 16, 2024 9:09 PM UTC
Hi @mr_fme
Crystal
mr_fme
  • Oct 17, 2024 1:05 PM UTC
Thank´s
