Query runs locally but not on FMEflow
  • Mar 11, 2026 1:16 PM UTC
  • 87 views
fme_hans
I have a query that reads data from a view. When I run the workspace that executes the query locally, it executes.
If I then set the workspace to FMEflow, the query no longer works. Local and FMEflow use the same Oracle client version.
The error message is meaningless: SQLCreator_11_<Rejected>: Termination Message: 'SQLCreator_11 output a <Rejected> feature. To continue translation when features are rejected, change 'Workspace Parameters' > Translation > 'Rejected Feature Handling' to 'Continue Translation''
The query does an select with a group by on a view. The same query runs in SQLdeveloper without errors.
The only strange thing i see is when i skip the 'group by' that there are fields with the value "<Missing>" Normally i see Null.
nielsgerrits
Forum|alt.badge.img+67
What versions FME Form & Flow are you using? Are both the same build?
fme_hans
  • Mar 11, 2026 1:31 PM UTC
FME Workbench = 2024.1  and FMEflow = 2025.2.2
hkingsbury
Forum|alt.badge.img+73
  • Mar 12, 2026 8:51 PM UTC
that should work, but ideally you’ll be running the same versions of Form and Flow.
Can you install Form 2025.2.2 and try uploading again?
