QGIS python library not able to load
  • Nov 19, 2024 4:01 PM UTC
  • 200 views
spalrobert
I am trying to run a custom python code that uses QGIS library in PythonCreator. However when I run the code I get this error:
Python Exception <ImportError>: DLL load failed while importing _core: The specified procedure could not be found.
I tried everything, I followed the documentation/manual how to setup custom python interpreter, I tried to setup dependencies and environment variables but none of that worked. Can someone tell me what am I doing wrong? Thanks!
evieatsafe
Forum|alt.badge.img+28
  • Nov 22, 2024 5:22 PM UTC
Hi ​@spalrobert a colleague mentioned that this is likely due to the Python interpreters' ability to find the correct dependencies required by the library you are using. Perhaps try comparing the paths from your QGIS environment and in FME. (assuming that this works in QGIS)
import sys
print(sys.path)
Add any paths that are present in QGIS but not FME.
sys.path.append(r"<missingPaths>")
Let us know if this returns different results.
spalrobert
  • Nov 28, 2024 10:59 AM UTC
Hi ​@evieatsafe print(sys.path) results in:
['C:\\Program Files\\FME\\FME2024_1\\python', 'C:\\Program Files\\FME\\FME2024_1\\python\\python312', 'C:\\Program Files\\FME\\FME2024_1\\python\\fme-plugins-py312.zip', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\python312.zip', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\DLLs', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\Lib', 'C:\\Program Files\\FME\\FME2024_1', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\Lib\\site-packages', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\Lib\\site-packages\\win32', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\Lib\\site-packages\\win32\\lib', 'C:\\Users\\fa08119\\AppData\\Local\\anaconda3\\Lib\\site-packages\\Pythonwin', 'C:\\Program Files\\FME\\FME2024_1\\plugins', 'C:\\Users\\fa08119\\HCP\\Documents\\FME\\Plugins\\Python', 'C:\\Users\\fa08119\\HCP\\Skrivbord']
I am not sure what to do with the second command - sys.path.append….
ali-safe
Forum|alt.badge.img+24
  • Jun 3, 2025 3:00 PM UTC
Hello, ​@spalrobert.
Let us know if you were able to resolve this issue. If not, there is a similar thread our colleague had mentioned on what to check for when linking and using the QGIS Python Library:
https://community.safe.com/transformers%2D9/qgis%2Din%2Dfme%2Dcalling%2Dpythoncaller%2D37634?tid=37634&fid=9
Best,
