pythonCaller fails when writer feature type use dynamic properties
  • Feb 3, 2015 4:51 PM UTC
  • 40 views
I encounter a problem that might be a bug with FME 2015. In my workspace I have aa python caller that use a custom python27 dll that was workinig without any problem a lot of times before.
Since I enabled the dynamic properties on a writer feature type, the python fails with that error message:
|Python Exception <WindowsError>: [Error 127] The specified procedure could not be found
If I uncheck the dynamic properties in the writer feature type, the pythonCaller process without error.
Should I report as a bug or there might be an explanation for this problem?
  • Feb 4, 2015 9:03 AM UTC
does it work if you use the Python interpreter that is installed with FME?
David
  • Feb 4, 2015 2:29 PM UTC
Hi David,
It seems to work with the the FME internal python, but my script can only run with a custom python installation because it is using numpy, gdal and geos.
After some tests, the conflict occur when I am importing geos:
 from django.contrib.gis import geos
If I disable the dynamic properties, the python caller does not fail. Same thing if I do not import geos, the script does not fail.
The dynamic properties in the feature type writer might use geos as well so a conflict occur?
