ProjectWise Connector - Pull out attribute information
  • Mar 19, 2019 1:19 AM UTC
  • 72 views
dberger106
Hi Team
I have had success with connecting into our ProjectWise instance using the connector (2018) and downloading files/folders. What I would like to do is to write out file properties such as Version, Description and Status (not just the output attributes that you have when you List )
Has anyone had any luck with this or any ideas I could try?
Thanks very much!
Dominique
xiaomengatsafe
Forum|alt.badge.img+11
Hi Dominique, Thanks for your question. Our connector is currently not able to retrieve version, description and status. It would be really helpful, if you could post this request as a new idea, and include some details about your use case. This will help us prioritize work, and understand your needs. Thank you!
Cheers,
Xiaomeng
