Problem with the Autodesk AutoCAD Map 3D Object Data reader
  • Apr 16, 2020 9:46 AM UTC
  • 5 replies
  • 127 views
dor1411993
Hello everyone,
I've had a problem with Object Data readerfor a few days now.
There is a file with objectdata on it that I want to process, and keep it as AutoCAD Map 3D Object Data
The problem is that no matter what I do, he always gives me this error message:
Even if I'm not doing anything in the process, just passing from reader to writer.
Does anyone have a clue what it could be?
Attached is the DWG file I want to process.
Thanks!
Best answer by itay
Shalom @dor1411993,
What seems to be the issue? I have read the file using both FME 2019.2 and 2020.0 with not problems.
Which FME version are you using?
Itay
dor1411993
  • Apr 18, 2020 6:21 PM UTC
Can anyone please help me?
itay
Forum|alt.badge.img+19
  • Apr 19, 2020 7:53 AM UTC
Shalom @dor1411993,
Itay
dor1411993
  • Apr 19, 2020 8:09 AM UTC
Shalom @dor1411993,
Itay
Hey @itay!
I work with the 2020 version.
Maybe it has to do with the license? I am currently using a trial license, and the next day I will switch to the license they gave me ..
It's really a weird that does not work for me ..
Toda!
itay
  • Apr 19, 2020 8:13 AM UTC
Hey @itay!
Toda!
I agree it should not matter, but having said that I have also experienced some changes when moving from a demo license to fixed.
I think the best you can do is contact Safe about it.
dor1411993
  • Apr 19, 2020 9:06 AM UTC
Ok.
Thanks!
I hope it really will help.
