Problem with AutoCAD_OD and Template File
  • Jul 23, 2013 8:26 PM UTC
  • 91 views
Hello,
I am trying to run a workbench with both the reader and the writer in the AUTOCAD_OD file format.
The problem is that when I set the Template File and run the workspace I get the following message:
Database conflict detected using the template file. See the documentation to avoid conflicts. Skipping the use of the template file.
So doing a little research I found this link:
http://docs.safe.com/fme/2009/html/ReadersWriters/autocad_od_-_templatefile.htm
Where it says that:
Note: The template file will be skipped for AUTOCAD_OD in certain cases to avoid name conflicts. If the reader format is AUTOCAD_OD, and the AUTOCAD_OD writer is the first writer in a multiple writer translation, the template file will be skipped.
The problem is I need to use an AUTOCAD_OD for the reader and the writer, so changing the file format is not an option.
Does anyone know any way to get around this problem?
Thanks,
Gabriel
Best answer by fmelizard
Hi Gabriel,
If adding an extra writer solves the issue, try to add a null writer and make sure its the first writer (at the top of all writers in the navigator).
Hope this helps,
Itay
fmelizard
Forum|alt.badge.img+22
  • Jul 24, 2013 6:14 PM UTC
Hi Gabriel,
Hope this helps,
Itay
  • Jul 29, 2013 9:02 PM UTC
Thanks, Itay
This solved my problem.
