Problem opening large MS Excel file in FME
I have a fairly large *.xlsx Excel file (27 MB), when I attempt to open this in an FME Desktop reader, upon selecting the "parameters" button or pressing "OK" the application crashes.
If I re save the file as a *.xls file, this removes data and re-saving as an xlsx file doesn't achieve anything either.
Any Ideas?
Forum|alt.badge.img+50
A quick fix might be to export it as a CSV from Excel and read that in to FME.
.xls has the negative side-effect of being limited to a max of 65536 rows so that's probably not enough.
I do think it would be a good idea to send the file in to Safe's support, maybe they can figure out why it's crashing FME.
fmelizard
Forum|alt.badge.img+19
  • May 24, 2019
Hi @saqibamin Please file a case via https://www.safe.com/support/report-a-problem/ and upload your problem Excel file to ftp://ftp.safe.com/incoming (no user name / password required) https://knowledge.safe.com/articles/91858/upload-a-file-to-the-safe-software-support-ftp.html
