PowerPointStyler Stacked Column Chart
  • April 29, 2020
  • 20 views
Forum|alt.badge.img+4
How do I set up my data to generate a stacked bar chart? For each CURRENT_OPERATOR_ALIAS category, I have 7 bins (RATE_CLASS) that I'd like to chart, where one bar is a CURRENT_OPERATOR_ALIAS with corresponding counts (COUNT(API) attribute), but I can't seem to plot 2 categories in the PowerPointStyler.
debbiatsafe
Forum|alt.badge.img+21
Hi @dmatranga
You will need to create each rate class (bins) as a list attribute and add each list attribute as a series in order to create a stacked column for each category (operator). I have attached a very simple example which creates a stacked column chart as shown in the screenshot below createstackedcolumnchart.fmw
You may need to modify the structure of your list attribute to achieve this. If you're able to attach a small sample of your data and your workspace, it would be helpful in identifying what needs to be changed.
