Postgre Read and Write SSL
  • Jan 9, 2014 3:28 PM UTC
  • 54 views
gschleusner
Is there a way to connect to a Postgre server  using an SSL connection?
Thanks,
Greg
fmelizard
Forum|alt.badge.img+22
  • Jan 9, 2014 4:29 PM UTC
Hi Greg
This is not currently supported and we have task to do this which seems to be planned for the coming year.
One of our customers proposed the following work-around which we haven't tested but may work:
"The workaround is to remove (by renaming) libpg.dll in $(FME_HOME)\\plugins\\postgis. FME seems to use the postgis.dll, where SSL-mode seems to work. You can't browse the "table list", but if You know schema and table (or view) name, You are able to connect. "
jpvo
  • Mar 5, 2014 2:26 PM UTC
Hi Ken,
Any precision concerning the planning for this SSL support for Postgre? We are very intereseted in this coming feature at INSER. (wanting to ba able to write on amazone applications).
Thanks,
JP.
fmelizard
  • Sep 23, 2014 9:50 PM UTC
Hi Greg and JP,
In FME 2015 beta, and in FME 2014 SP3 as well I think, PostgreSQL supports SSL connections via OpenSSL DLLs.
FME 2015 beta and FME 2014 SP3 can be downloaded from:
http://www.safe.com/support/support-resources/fme-downloads/
http://www.safe.com/support/support-resources/fme-downloads/beta/
Thanks,
Natalie
