POSTGIS Writer: Fanout for feature type [postgis_table_name] failed to find feature type template ''
  • Dec 9, 2015 7:50 AM UTC
  • 160 views
The post title
is the error I'm getting in the FME log when I try to run a workbench which has already worked flawlessly a lot of times.
It looks to me a database-related issue (template?) but I can't understand it and can't find any solution. I have no fanout and database configuration has to my knowledge not changed. I did not even change writers configuration.
My FME version:
2015.1.1.0 (20150715 - Build 15515 - WIN32)
Any ideas on how to handle that?
mark2atsafe
Forum|alt.badge.img+59
Hi. I looked up the message and it appears to be a problem that occurred in version 2015.1.1 (and some 2016.0 beta builds). The good news is that this is fixed in FME 2015.1.2. Can you upgrade to that version and try again?
The one thing I don't know is if the workspace has been damaged by the bug. If you are still having problems after upgrading, please contact the support team for assistance (http://safe.com/support). Let them know it is re PR#63806
Apologies for any inconvenience. I hope this helps resolve the problem for you.
  • Dec 10, 2015 1:25 PM UTC
Hello! Thanks for the hint. I'll try to convince our IT ppl to do an extraordinary update and then post an update here.
  • Mar 13, 2017 6:35 PM UTC
Hi Mark,
I am seeing the same issue at 2016.1.1.0, is this bug fixed at that version?
