postgis schema
  • Jun 12, 2015 7:51 AM UTC
  • 7 replies
  • 197 views
matself
Forum|alt.badge.img+9
Hi!
This has been covered in part, but I would like to expand.
The way to write to a specific schema in PostGIS is to use what FME calls 'table qualifier'.
However, this setting is disregarded in DYNAMIC mode, and defaults to the public schema.
Is this a bug, or by design?
I am trying to set up a standard method for PostGIS writing, which should be able to convert 30-50 shapefiles to a specific schema.
Doing the same with the writer in static mode works, but becomes very impractical. I am aware that you can alter the writer settings for all flows, but any processing in beteween, such as creating an UUID must be applied to all flows one by one.
Regards, Mats.E
fmelizard
Forum|alt.badge.img+22
  • Jun 13, 2015 6:45 AM UTC
Hi Mats,
I talked with the Database Team and we think this should be working but at first blush appears not to be.  I've created a case for it and support will verify that it doesn't work, see if there's a workaround for the short term, and then we'll try to get it fixed for a 2015.1.x.
Sorry about this one.
Dale
fmelizard
  • Jun 15, 2015 9:43 PM UTC
Hi Mats,
We looked into this further. FME's PostGIS writer honors "Table Qualifier" with feature type fanout (where the output table name comes from an attribute), but not dynamic writing (which is even more flexible than feature type fanout and additonally copies schemas from readers).
We understand the causes behind this limitation and do plan to address it in future - but possibly not soon enough for your use case. Could you let us know if the following workaround is sufficient?
1. Find the attribute that contains the table name FME would write. In the default dynamic case, this is fme_feature_type. If the name is different, adjust the following steps to match.
2. Use an AttributeCreator to create a new attribute containing the string "<table qualifier>.<fme_feature_type>".
3. In the destination feature type General tab, set "Table Name" to this new attribute.
4. In the destination feature type General tab, Dynamic Properties section, set "Schema Definiton Name" to Attribubutre Value -> fme_feature_type. You may need to check "fme_feature_type" in the source feature type properties, Format Attributes tab, to make this option available.
Regards,
Paul
Paul Nalos | Database Team Lead
fmelizard
Hi Mats,
Regards,
Paul
Safe Software Inc.
T 604.501.9985 x 301
paul.nalos@safe.com | www.safe.com
matself
  • Jun 17, 2015 10:18 AM UTC
Hi Paul!
That is absolutely brilliant. It worked at the first attempt, and further development such as putting a uuid creator on the path worked as well. I just put some 6.3 million objects into PostGIS, GIST:ed and vaccuumed in 46 minutes.
I did try to inject the table qualifier as an attribute, but failed to make it dynamic. But your suggestion also showed me how to alter table names in a workflow, something I have not managed to figure out by myself before but often needed.
The workaround is simple enough, but it would surely be fine if the table qualifier did work in dynamic mode as well. I see no reason why not, and it is necessary I think for structured PostGIS storage.
Best regards, Mats.E
Hi Mats,
Regards,
Paul
Was a fix ever implemented into 2016? I currently have the same issue described by @matself. The work around described by@paulatsafe does work, but would be nice to have this functionality working properly for a tidy workbench!
mark2atsafe
Forum|alt.badge.img+59
Hi @thomaswicks202 - I don't believe this has been fixed yet. It looks like PR#62362 and that is still an open issue. I will add a link to this thread and see if I can increase the priority. Apologies for the problems it is causing you. If you would like, please do contact our support team directly (safe.com/support) so you can get direct updates on this issue.
dollargis
  • Apr 25, 2018 7:55 AM UTC
It seems that this is still unresolved in FME2018.
For my project I need to dynamically write tables to different schemas
