postgis - problems with adding data to database
  • May 20, 2014 1:27 PM UTC
  • 47 views
I`m using FME 2014 to populate a table in our postGIS db. The problem is that the data is somehow not beeing loaded into the database. The logfile is telling that,
"Failed to build an SQL statement because the feature lacked an 'fme_where' attribute. Update and delete features require an 'fme_where' attribute to be specified"
I´m guessing I have to set the fme_where attribute, but is really lost in why and howto set it? What should fme_where point to or include? Can someone help me in the right direction?
Christian
  • May 20, 2014 1:57 PM UTC
it isn't normally necessary to set the fme_where attribute if you're just appending to an existing table. Could you post a screenshot of the the writer config and the relevant section of the error in the log?
David
  • May 20, 2014 2:46 PM UTC
