PolygonPatch builder
  • Oct 15, 2015 9:57 AM UTC
  • 49 views
I want to make several polygon features as a single GML Surface feature. I need to convert polygons into PolygonPatches and then aggregare them into single Surface (with several polygon patches) grouped by specified attribute. How to get this done?
I tried Aggregator, GeometryCoercer, different combinations, but, nothing.
  • Oct 16, 2015 8:28 AM UTC
GML MultiSurface can be created from an aggregate feature with the GeometryExtractor. I'm wondering if it can be modified into GML Surface through some XML and/or String operations.
Or, use the GeometryExtractor to create GML Surface for each single polygon; extract PolygonPatch element form the resulting Surface; and then construct the required GML Surface that contains multiple PolgyonPatch elements.
Anyway, some transformers in the XML category might help you.
Takashi
  • Oct 16, 2015 9:18 AM UTC
Takashi,
I already made Surface using this approach in PythonCaller. But it is 'slow' because it uses string concatenations, xml fragmentation and so on.
If there is no FME built-in transformer, I'll optimize mine a little bit more.
Thanks anyway!
  • Oct 16, 2015 4:21 PM UTC
Python is also good, but I think XML transformers are also worth to try.
e.g.
XQuery Expression parameter (XMLXQueryUpdater)
declare namespace gml='http://www.opengis.net/gml/3.2';
<gml:Surface>
<gml:patches>
{//gml:PolygonPatch}
</gml:patches>
</gml:Surface>
