Polyface dwg split into separate buildings
  • Dec 17, 2018 4:19 PM UTC
  • 72 views
I have a 3D model with buildings originally from las data. The model is in polyface .dwg format and for performance improvements I want to split the model into separate buildings.
How would I go about something like this? Is there some way of splitting this data using a 2D grid? If so, how do I handle buildings that are being cut into two? Other suggestions?
daveatsafe
Forum|alt.badge.img+24
  • Dec 18, 2018 7:41 PM UTC
Hi @leif,
Can you add a small sample of the existing 3D model? This would help us figure out a way to split the buildings.
danilo_fme
Forum|alt.badge.img+58
  • Dec 23, 2018 10:41 PM UTC
Hi @leif
I agree with @DaveAtSafe that is better to share us your sample to help you.
Thanks,
Danilo
